Salta al contenuto principale
How To Replace the Battery on a Conair Trimmer (GMT15NCS)
Cosa ti serve
  1. How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: passo 1, immagine 1 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: passo 1, immagine 2 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: passo 1, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove the two screws holding the trimmer blade in place.
    • Hold down the trimmer blades to make it easier to remove the screws.
  2. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 2, immagine 1 di 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 2, immagine 2 di 2
    • Lift both of the trimmer blades off of the plastic guard.
  3. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 3, immagine 1 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 3, immagine 2 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 3, immagine 3 di 3
    • Separate the plastic guard from the casing by using the metal spudger tool.
    • Pry up at the top of the plastic guard, NOT the bottom.
  4. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 4, immagine 1 di 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 4, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the two screws inside the casing.
    • Tilt the trimmer to prevent the screws from falling into the casing.
  5. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 5, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the casing screw at the bottom of the trimmer.
    • Tilt the trimmer so gravity helps the screw fall out.
  6. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 6, immagine 1 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 6, immagine 2 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 6, immagine 3 di 3
    • Fire Hazard: Be careful not to stick the metal spudger too deep when prying to avoid puncturing the battery.
    • Separate the casing at the seam using the metal spudger to release the clips.
    • Use a twisting or prying motion, in any direction, to separate the casing.
    • The same process may be needed on the other side's seam to release clips.
  7. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 7, immagine 1 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 7, immagine 2 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 7, immagine 3 di 3
    • Remove the two screws holding the battery setup in place.
    • Take note of the position of the positive and negative terminals of the battery on the setup.
  8. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 8, immagine 1 di 1
    • Lift the battery setup out of the casing.
    • Take note of how the battery setup lays in the casing.
  9. How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 9, immagine 1 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 9, immagine 2 di 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): passo 9, immagine 3 di 3
    • The soldering iron with be hot.
    • Using the soldering iron, desolder the battery at the connection to remove the battery from the setup.
    • Use iFixit's guide on Come saldare e dissaldare componenti elettrici if you are not familiar using a soldering tool.
Conclusione
To reassemble your device, solder the new 2.4 V battery into the setup, and follow the instructions in reverse.
Altre 2 persone hanno completato questa guida.
1Commento della guida
Where can I buy the batery
Wenceslao Hernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 135
Tutti i Tempi: 12,366
