Salta al contenuto principale
Hover-1 Eagle Front Wheel Replacement
Cosa ti serve
  1. Hover-1 Eagle Front Wheel Replacement, Front Wheel: passo 1, immagine 1 di 1
    • Wedge the spudger underneath the red reflective sticker and peel it back.
  2. Hover-1 Eagle Front Wheel Replacement: passo 2, immagine 1 di 2 Hover-1 Eagle Front Wheel Replacement: passo 2, immagine 2 di 2
    • Remove the four 2mm screws with a Phillips #2 screwdriver.
  3. Hover-1 Eagle Front Wheel Replacement: passo 3, immagine 1 di 1
    • Remove the plastic axle cover by sliding the cover downwards.
  4. Hover-1 Eagle Front Wheel Replacement: passo 4, immagine 1 di 1
    • Use pliers to remove the locknut.
  5. Hover-1 Eagle Front Wheel Replacement: passo 5, immagine 1 di 1
    • Slide the wheel out in a downwards motion to remove it from the fork.
Conclusione
Altre 3 persone hanno completato questa guida.
Andrew Gaskell
Membro da: 01/23/20
1.008 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G2, White Winter 2020 Membro di Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Membri
6 Guide realizzate
17 Commenti
Good afternoon.
And how do you remove the cables?
Diogo Silva - Replica
i would like to know the same thing
it'sluigiplays 87 - Replica
where do i get the front wheel front i cant find where to buy a new front wheel
leon watts - Replica
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
Mk Sub-zero - Replica
Does anybody know how to fix the handlebar/front wheel alignment?
robandkim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 61
Tutti i Tempi: 6,484
