Salta al contenuto principale
Hover-1 Eagle Back Wheel Replacement
Cosa ti serve
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: passo 1, immagine 1 di 1
    • Peel off the reflective red axle sticker using a plastic spudger.
  2. Hover-1 Eagle Back Wheel Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
  3. Hover-1 Eagle Back Wheel Replacement: passo 3, immagine 1 di 3 Hover-1 Eagle Back Wheel Replacement: passo 3, immagine 2 di 3 Hover-1 Eagle Back Wheel Replacement: passo 3, immagine 3 di 3
    • Grip the deck flare and slide it towards the tail end of the scooter.
  4. Hover-1 Eagle Back Wheel Replacement: passo 4, immagine 1 di 1
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
  5. Hover-1 Eagle Back Wheel Replacement: passo 5, immagine 1 di 3 Hover-1 Eagle Back Wheel Replacement: passo 5, immagine 2 di 3 Hover-1 Eagle Back Wheel Replacement: passo 5, immagine 3 di 3
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
  6. Hover-1 Eagle Back Wheel Replacement: passo 6, immagine 1 di 2 Hover-1 Eagle Back Wheel Replacement: passo 6, immagine 2 di 2
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
Conclusione
To reassemble your device, repeat Steps 1-4 in reverse order.
Altre 4 persone hanno completato questa guida.
Andrew Gaskell
Membro da: 01/23/20
1.008 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G2, White Winter 2020 Membro di Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Membri
6 Guide realizzate
Un commento
Where do you buy the wheels
Thanks
antonio flores - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,268
