Salta al contenuto principale
Hover-1 Charger LED Headlight Replacement
Cosa ti serve
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: passo 1, immagine 1 di 2 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: passo 1, immagine 2 di 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: passo 2, immagine 1 di 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: passo 3, immagine 1 di 2 Hover-1 Charger LED Headlight Replacement: passo 3, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: passo 4, immagine 1 di 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: passo 5, immagine 1 di 2 Hover-1 Charger LED Headlight Replacement: passo 5, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: passo 6, immagine 1 di 2 Hover-1 Charger LED Headlight Replacement, LED Headlight: passo 6, immagine 2 di 2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: passo 7, immagine 1 di 2 Hover-1 Charger LED Headlight Replacement: passo 7, immagine 2 di 2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: passo 8, immagine 1 di 1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
Conclusione
Benji Forest
Membro da: 10/10/19
266 Reputazione
2 Guide realizzate
Cal Poly, Team S12-G1, Regan Fall 2019 Membro di Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 205
