Salta al contenuto principale
Hover-1 Charger Gyroscope Sensor Board Replacement
Cosa ti serve
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: passo 1, immagine 1 di 2 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: passo 1, immagine 2 di 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 2, immagine 1 di 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 3, immagine 1 di 2 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 3, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 4, immagine 1 di 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 5, immagine 1 di 2 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 5, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: passo 6, immagine 1 di 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: passo 6, immagine 2 di 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: passo 6, immagine 3 di 3
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 7, immagine 1 di 2 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 7, immagine 2 di 2
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 8, immagine 1 di 3 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 8, immagine 2 di 3 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 8, immagine 3 di 3
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 9, immagine 1 di 1
    • Remove the gyroscope sensor board.
Conclusione
Cal Poly, Team S12-G1, Regan Fall 2019 Membro di Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Membri
6 Guide realizzate
4 Commenti
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - Replica
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - Replica
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - Replica
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,573
