Salta al contenuto principale
Hover-1 Charger Bluetooth Speaker Replacement
Cosa ti serve
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: passo 1, immagine 1 di 2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: passo 1, immagine 2 di 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: passo 2, immagine 1 di 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: passo 3, immagine 1 di 2 Hover-1 Charger Bluetooth Speaker Replacement: passo 3, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: passo 4, immagine 1 di 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: passo 5, immagine 1 di 2 Hover-1 Charger Bluetooth Speaker Replacement: passo 5, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: passo 6, immagine 1 di 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: passo 7, immagine 1 di 2 Hover-1 Charger Bluetooth Speaker Replacement: passo 7, immagine 2 di 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: passo 8, immagine 1 di 2 Hover-1 Charger Bluetooth Speaker Replacement: passo 8, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: passo 9, immagine 1 di 2 Hover-1 Charger Bluetooth Speaker Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: passo 10, immagine 1 di 1
    • Remove the speaker and circuit board from the outer shell.
Conclusione
Cal Poly, Team S12-G1, Regan Fall 2019 Membro di Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,290
