Salta al contenuto principale
Hover-1 Charger Battery Replacement
Cosa ti serve
  1. Hover-1 Charger Battery Replacement, Battery: passo 1, immagine 1 di 2 Hover-1 Charger Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Battery Replacement: passo 2, immagine 1 di 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Battery Replacement: passo 3, immagine 1 di 2 Hover-1 Charger Battery Replacement: passo 3, immagine 2 di 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  4. Hover-1 Charger Battery Replacement: passo 4, immagine 1 di 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Battery Replacement: passo 5, immagine 1 di 2 Hover-1 Charger Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
  6. Hover-1 Charger Battery Replacement: passo 6, immagine 1 di 2 Hover-1 Charger Battery Replacement: passo 6, immagine 2 di 2
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
  7. Hover-1 Charger Battery Replacement: passo 7, immagine 1 di 3 Hover-1 Charger Battery Replacement: passo 7, immagine 2 di 3 Hover-1 Charger Battery Replacement: passo 7, immagine 3 di 3
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
  8. Hover-1 Charger Battery Replacement: passo 8, immagine 1 di 1
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
  9. Hover-1 Charger Battery Replacement: passo 9, immagine 1 di 1
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
  10. Hover-1 Charger Battery Replacement: passo 10, immagine 1 di 1
    • Remove the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S12-G1, Regan Fall 2019 Membro di Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Membri
6 Guide realizzate
Un commento
Can I replace my battery 25.2v to a 36v.
Airie Green - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 213
Tutti i Tempi: 7,036
