Salta al contenuto principale
Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement
Visualizzazioni: 9658
Visualizza statistiche:
Ultime 24 ore:
Ultimi 7 giorni:
20
Ultimi 30 giorni:
118
Tutti i Tempi:
9.658
Commenti: 1
1 commento sui passaggi.
Completato: 7
7 persone hanno contrassegnato questa guida come "completata". Sarai il prossimo?
Preferiti: 0
Nessuno ha preferito (e si è iscritto) questa guida. Sarai il primo?
Tempo necessario: 1 - 3 ore
Difficoltà: Moderato
Introduzione
Vai al passo 1 ↓
This guide shows how to remove and replace the crankshaft on the Honda HRS216K6 lawn mower.
Drain the fuel from the fuel tank before you begin this procedure. Any fuel remaining in the tank will spill out. Be ready to contain any spillage.
Drain the oil from the motor before you begin this procedure. Any engine oil remaining in the motor will spill out. Be ready to contain any spillage.
You will need to refill the engine oil after this procedure. The lawn mower requires up to 0.55 liters of SAE 10W-30 oil.
You will need to reapply liquid gasket after this procedure. Use ThreeBond 1216, Hondabond HT, or equivalent.
You may need a blowtorch to help heat up and loosen the flywheel.
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the spark plug: passo 1, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the spark plug: passo 1, immagine 2 di 2
      • Before you begin, make sure the engine is switched off and cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Restrict fuel flow: passo 2, immagine 1 di 1
      • Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
      • Turn the fuel cutoff valve clockwise so the handle becomes vertical.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the fuel tank: passo 3, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the fuel tank: passo 3, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the fuel tank: passo 3, immagine 3 di 3
      • Use needle nose pliers to compress and slide the tube clamp away from the cutoff valve's fitting.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 4, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 4, immagine 2 di 2
      • Residual fuel may leak out of this hose. Be ready to catch any spillage.
      • Disconnect the fuel line from the cutoff valve.
      Chiedi a FixBot
      Aggiungi Commento
    3. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the brake cable: passo 5, immagine 1 di 1
      • Use needle nose pliers to squeeze the two locking tabs on the brake cable latch.
      Chiedi a FixBot
      Aggiungi Commento
    4. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 6, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 6, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 6, immagine 3 di 3
      • Pull to unlatch the cable sheath.
      • Pull the brake cable away from the motor.
      Chiedi a FixBot
      Aggiungi Commento
    5. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 7, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 7, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 7, immagine 3 di 3
      • Push the cable towards the cable anchor to give it enough slack to be removed.
      • Remove the brake cable from the motor.
      Chiedi a FixBot
      Aggiungi Commento
    6. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the pull start cord: passo 8, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the pull start cord: passo 8, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Disconnect the pull start cord: passo 8, immagine 3 di 3
      • Pull the pull start cord out of the small opening on the handle post and remove it.
      Chiedi a FixBot
      Aggiungi Commento
    7. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the fan cover: passo 9, immagine 1 di 1
      • Remove the three 10 mm nuts securing the fan cover.
      Chiedi a FixBot
      Aggiungi Commento
    8. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 10, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 10, immagine 2 di 2
      • Remove the fan cover.
      • The fuel tank is connected to the fan cover. They will both come out as one unit.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the cooling fan: passo 11, immagine 1 di 1
      • Remove the 19 mm nut securing the flywheel and cooling fan to the motor.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 12, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 12, immagine 2 di 2
      • Remove the washer on top of the cooling fan.
      • Remove the cooling fan.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Loosen the flywheel: passo 13, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Loosen the flywheel: passo 13, immagine 2 di 2
      • Caution: The flywheel may come loose at any time during this step, potentially sending itself and the puller into the air. Before you begin this step, be sure to wear PPE.
      • Use a universal puller to loosen the flywheel from the tapered pressure fit on the end of the crankshaft.
      • Attach the universal puller arms underneath the denoted "puller" sections on the flywheel.
      • Use a wrench to torque down the puller to slowly loosen the flywheel.
      • This may take a lot of force.
      • If the flywheel seems to become stuck after significant pressure is applied with the universal puller, use a blowtorch to slowly apply heat where the flywheel contacts the crankshaft.
      • The flywheel will "pop" off the crankshaft once loose.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the flywheel: passo 14, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the flywheel: passo 14, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the flywheel: passo 14, immagine 3 di 3
      • Remove the flywheel.
      • If the flywheel became deformed at all during the last step, it will need to be replaced before reinstallation.
      • During reassembly, make sure to align the flywheel with the flywheel key.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the flywheel key: passo 15, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the flywheel key: passo 15, immagine 2 di 2
      • Use needle nose pliers to remove the flywheel key from its slot in the crankshaft.
      • During reinstallation, make sure the key is fully seated in the slot. Otherwise the flywheel will not fit correctly.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the blade: passo 16, immagine 1 di 1
      • Loosen, but don't remove, the shiny 14 mm blade holder bolt.
      • Remove the two matte 14 mm bolts securing the blade to the blade holder.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 17, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 17, immagine 2 di 2
      • Remove the blade.
      • If the blade is heavily used, it may be sharp in some areas. If this is the case, use gloves to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    3. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the blade holder: passo 18, immagine 1 di 1
      • Fully remove the 14 mm bolt securing the blade holder to the crankshaft.
      Chiedi a FixBot
      Aggiungi Commento
    4. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 19, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 19, immagine 2 di 2
      • Remove the blade holder.
      • If the blade holder is difficult to remove by hand, use a pry bar for more leverage.
      • The blade holder will come out with its accompanying shaft key.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the motor: passo 20, immagine 1 di 1
      • Remove the four 12 mm bolts securing the motor to the frame.
      • Once these bolts are removed, the engine will be free to fall off the mower frame. If you are removing the bolts while the mower is on its side, you may need another person to steady the motor.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 21, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 21, immagine 2 di 2
      • Lift the engine off of the mower frame and remove it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Flip the motor over: passo 22, immagine 1 di 1
      • Flip the motor over such that it's resting on the three mounting posts for the fan cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the governor arm: passo 23, immagine 1 di 1
      • Loosen, but don't remove, the 10 mm bolt securing the governor arm to the motor.
      Chiedi a FixBot
      Aggiungi Commento
    3. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 24, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 24, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 24, immagine 3 di 3
      • Remove the governor arm from the mounting post.
      • Don't completely remove the governor arm. It's still connected to the motor with some springs.
      • Set the governor arm aside.
      Chiedi a FixBot
      Aggiungi Commento
    4. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove oil pan: passo 25, immagine 1 di 1
      • Remove the eight 10 mm flange bolts securing the oil pan to the engine block.
      Chiedi a FixBot
      Aggiungi Commento
    5. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 26, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 26, immagine 2 di 2
      • Loosen the oil pan by inserting a flathead screwdriver in the two recessed access points on either side of the engine block.
      Chiedi a FixBot
      Aggiungi Commento
    6. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 27, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 27, immagine 2 di 2
      • Use a flathead screwdriver to pry the case apart.
      • Work your way around the entire mating surface to loosen the oil pan.
      • Any residual engine oil may start to leak out. Be ready to contain any spillage.
      Chiedi a FixBot
      Aggiungi Commento
    7. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 28, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 28, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 28, immagine 3 di 3
      • Lift the oil pan straight up and remove it.
      • Any residual engine oil may leak out. Be ready to contain any spillage.
      • Before reassembly, clean off old liquid gasket from the engine block mating surfaces thoroughly before applying new HondaBond or equivalent liquid gasket.
      • During reassembly, loosely tighten each flange bolt and then tighten center-out to 9 ft-lb (12 N-m).
      • Wait at least 20 minutes after reassembly before adding oil to the engine.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Position the piston: passo 29, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Position the piston: passo 29, immagine 2 di 2
      • Rotate the crankshaft by hand to position the piston at top dead center (TDC) by aligning the two marks:
      • The arrow on the crankshaft
      • The seam on the cylinder block
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the crankshaft: passo 30, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the crankshaft: passo 30, immagine 2 di 2
      • Remove the thrust washer.
      • Note the orientation of the washer—it only goes on one way.
      Chiedi a FixBot
      Aggiungi Commento
    3. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 31, immagine 1 di 1
      • Remove the two 10 mm bolts securing the end cap to the connecting rod.
      Chiedi a FixBot
      Aggiungi Commento
    4. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 32, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 32, immagine 2 di 2
      • Remove the connecting rod end cap.
      Chiedi a FixBot
      Aggiungi Commento
    5. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 33, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 33, immagine 2 di 2
      • Slip the timing belt off of the timing pulley on the crankshaft.
      Chiedi a FixBot
      Aggiungi Commento
    6. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 34, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 34, immagine 2 di 2
      • Pull the crankshaft directly up and out until it's restricted by the timing belt.
      • This shouldn't require much force—don't stretch the timing belt.
      Chiedi a FixBot
      Aggiungi Commento
    7. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 35, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 35, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 35, immagine 3 di 3
      • Slip the timing belt around the counterweights on the crankshaft.
      • The other side of the timing belt is connected to the cam pulley inside of the cylinder head. It can slip off during this step. If it does, peer up into the cylinder head and reseat the timing belt on the cam pulley.
      Chiedi a FixBot
      Aggiungi Commento
    8. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement: passo 36, immagine 1 di 1
      • With the crankshaft free of the timing belt, remove it from the motor.
      Chiedi a FixBot
      Aggiungi Commento
    9. Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the timing pulley: passo 37, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the timing pulley: passo 37, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Crankshaft Replacement, Remove the timing pulley: passo 37, immagine 3 di 3
      • Remove the timing pulley from the crankshaft.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
173.200 Reputazione
442 guide realizzate
iFixit Membro di iFixit
Staff
121 Membri
72.907 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Ultime 24 ore: 1
Ultimi 7 giorni: 20
Ultimi 30 giorni: 118
Tutti i Tempi: 9,658
