Salta al contenuto principale
Holmes HEH8031 Circuit Board Replacement
Cosa ti serve
  1. Holmes HEH8031 Circuit Board Replacement, Housing: passo 1, immagine 1 di 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Circuit Board Replacement: passo 2, immagine 1 di 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Circuit Board Replacement: passo 3, immagine 1 di 2 Holmes HEH8031 Circuit Board Replacement: passo 3, immagine 2 di 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Circuit Board Replacement, Circuit Board Removal: passo 4, immagine 1 di 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Circuit Board Replacement, Circuit Board: passo 5, immagine 1 di 3 Holmes HEH8031 Circuit Board Replacement, Circuit Board: passo 5, immagine 2 di 3 Holmes HEH8031 Circuit Board Replacement, Circuit Board: passo 5, immagine 3 di 3
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Circuit Board Replacement: passo 6, immagine 1 di 2 Holmes HEH8031 Circuit Board Replacement: passo 6, immagine 2 di 2
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
Conclusione
Chris Shaffer
Membro da: 10/12/16
255 Reputazione
2 Guide realizzate
IUPUI, Team 2-1, Baechle Fall 2016 Membro di IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 973
