Salta al contenuto principale
Hisense Sero 8 Motherboard Replacement
Cosa ti serve
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Hisense Sero 8 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Hisense Sero 8 Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: passo 2, immagine 1 di 2 Hisense Sero 8 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: passo 5, immagine 1 di 3 Hisense Sero 8 Motherboard Replacement: passo 5, immagine 2 di 3 Hisense Sero 8 Motherboard Replacement: passo 5, immagine 3 di 3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Conclusione
Katharina
Membro da: 02/23/15
506 Reputazione
2 Guide realizzate
USF Tampa, Team 1-2, Leahy Winter 2015 Membro di USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,409
