Salta al contenuto principale
Hisense Chromebook C11 Hard Drive Replacement
Cosa ti serve
  1. Hisense Chromebook C11 Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Hard Drive Replacement, Battery: passo 4, immagine 1 di 1
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with the Phillips #000 screwdriver.
  5. Hisense Chromebook C11 Hard Drive Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to unplug the battery.
  6. Hisense Chromebook C11 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
  7. Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Unscrew all of the screws that you can access on the hard drive.
    • If you cannot reach the screw beneath the black strip, move on to the next step.
  8. Hisense Chromebook C11 Hard Drive Replacement: passo 8, immagine 1 di 3 Hisense Chromebook C11 Hard Drive Replacement: passo 8, immagine 2 di 3 Hisense Chromebook C11 Hard Drive Replacement: passo 8, immagine 3 di 3
    Compra
    • Remove the black strip using the tweezers.
  9. Hisense Chromebook C11 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Unscrew the screw beneath the black strip if you haven't done so already.
  10. Hisense Chromebook C11 Hard Drive Replacement: passo 10, immagine 1 di 2 Hisense Chromebook C11 Hard Drive Replacement: passo 10, immagine 2 di 2
    • Remove the ribbon with the tweezers.
  11. Hisense Chromebook C11 Hard Drive Replacement: passo 11, immagine 1 di 2 Hisense Chromebook C11 Hard Drive Replacement: passo 11, immagine 2 di 2
    • Using the tweezers, carefully remove the latches attaching the silver computer chip.
  12. Hisense Chromebook C11 Hard Drive Replacement: passo 12, immagine 1 di 2 Hisense Chromebook C11 Hard Drive Replacement: passo 12, immagine 2 di 2
    • Continue gently removing all remaining points of attachment.
  13. Hisense Chromebook C11 Hard Drive Replacement: passo 13, immagine 1 di 1
    • Carefully remove the hard drive.
Conclusione
USF Tampa, Team S1-G3, Leahy Fall 2018 Membro di USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,148
