Salta al contenuto principale
Hipstreet Equinox 2 Motherboard Replacement
Cosa ti serve
  1. Hipstreet Equinox 2 Motherboard Replacement, Rear Case: passo 1, immagine 1 di 1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
  4. Hipstreet Equinox 2 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
  5. Hipstreet Equinox 2 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
  6. Hipstreet Equinox 2 Motherboard Replacement: passo 6, immagine 1 di 1
    • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
Conclusione
Clemson, Team 15-8, Shirley Winter 2015 Membro di Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 373
