Salta al contenuto principale
Heyday Suitcase Turntable Needle Replacement
  1. Heyday Suitcase Turntable Needle Replacement, Needle: passo 1, immagine 1 di 2 Heyday Suitcase Turntable Needle Replacement, Needle: passo 1, immagine 2 di 2
    • Before you begin the repair, turn off the record player and unplug the power cord.
    • Remove cartridge lock by pushing inwards (towards the needle arm, while lightly squeezing the sides by hand. Then pull downwards and towards you to disengage the locking hook. This will unhook the lock between cartridge and base.
  2. Heyday Suitcase Turntable Needle Replacement: passo 2, immagine 1 di 1
    • Disconnect the wires from the cartridge.
Conclusione
To reassemble your device, follow these instructions in reverse order. Replace the needle by clipping it back onto the cartridge and then reconnect the wires to the correct part of the cartridge.
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 429
