Salta al contenuto principale
Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement
Cosa ti serve
  1. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Find the location of the damaged speaker. The speaker can be located above the battery pack on the forearm.
    • Find the damaged wire. It must be replaced with a new one.
  2. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: passo 2, immagine 1 di 2 Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: passo 2, immagine 2 di 2
    • Desolder the damaged wire from the speaker and replace it with a new one.
    • It will be beneficial to use the wire stripping tool in order to do this.
  3. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: passo 3, immagine 1 di 1
    • Once the new wire is attached to the speaker, it must then be reattached to the circuit board.
    • Once the new wires are securely placed in the correct spot, the hand can be put back together.
Conclusione
Tori Mariano
Membro da: 02/24/23
347 Reputazione
1 Guida realizzata
Marist, Team 1-3, Chaterdon Spring 2023 Membro di Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 89
