Salta al contenuto principale
Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement
Cosa ti serve
  1. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 2, immagine 1 di 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 3, immagine 1 di 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 4, immagine 1 di 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 4, immagine 2 di 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 5, immagine 1 di 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 5, immagine 2 di 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: passo 6, immagine 1 di 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 7, immagine 1 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 7, immagine 2 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 8, immagine 1 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 8, immagine 2 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 8, immagine 3 di 3
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 9, immagine 1 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 9, immagine 2 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 9, immagine 3 di 3
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: passo 10, immagine 1 di 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: passo 10, immagine 2 di 2
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 11, immagine 1 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 11, immagine 2 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 11, immagine 3 di 3
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 12, immagine 1 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 12, immagine 2 di 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: passo 12, immagine 3 di 3
    • Pull the cameras out of their resting places in a straight upward motion.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 609
