Salta al contenuto principale
HTC Vive Head Strap Replacement
Cosa ti serve
  1. HTC Vive Head Strap Replacement, Release the upper head strap: passo 1, immagine 1 di 2 HTC Vive Head Strap Replacement, Release the upper head strap: passo 1, immagine 2 di 2
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
  2. HTC Vive Head Strap Replacement, Remove the upper head strap: passo 2, immagine 1 di 2 HTC Vive Head Strap Replacement, Remove the upper head strap: passo 2, immagine 2 di 2
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
  3. HTC Vive Head Strap Replacement, Remove the right side of the head strap: passo 3, immagine 1 di 3 HTC Vive Head Strap Replacement, Remove the right side of the head strap: passo 3, immagine 2 di 3 HTC Vive Head Strap Replacement, Remove the right side of the head strap: passo 3, immagine 3 di 3
    • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
    • Slide the right side of the head strap through its metal loop to remove it.
  4. HTC Vive Head Strap Replacement, Remove the left side of the head strap: passo 4, immagine 1 di 3 HTC Vive Head Strap Replacement, Remove the left side of the head strap: passo 4, immagine 2 di 3 HTC Vive Head Strap Replacement, Remove the left side of the head strap: passo 4, immagine 3 di 3
    • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
    • Slide the left side of the head strap through its metal loop to remove it.
  5. HTC Vive Head Strap Replacement, Remove the head strap: passo 5, immagine 1 di 3 HTC Vive Head Strap Replacement, Remove the head strap: passo 5, immagine 2 di 3 HTC Vive Head Strap Replacement, Remove the head strap: passo 5, immagine 3 di 3
    • Slide the head strap along the cable, away from the Vive.
    • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
Conclusione
Altre 6 persone hanno completato questa guida.
Adam O'Camb
Membro da: 04/11/15
196.326 Reputazione
416 Guide realizzate
3 Commenti
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
Elias - Replica
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
Ryan Stargell -
how to fix my headset strap on my vive i nead some help on it can you show me how.
GreggTHhompson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 62
Tutti i Tempi: 5,976
