Salta al contenuto principale
HTC Trophy Power Button Replacement
Cosa ti serve
  1. HTC Trophy Power Button Replacement, Battery: passo 1, immagine 1 di 3 HTC Trophy Power Button Replacement, Battery: passo 1, immagine 2 di 3 HTC Trophy Power Button Replacement, Battery: passo 1, immagine 3 di 3
    • Power off the phone before starting.
    • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
  2. HTC Trophy Power Button Replacement: passo 2, immagine 1 di 3 HTC Trophy Power Button Replacement: passo 2, immagine 2 di 3 HTC Trophy Power Button Replacement: passo 2, immagine 3 di 3
    • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
    • Apply a small force towards the bottom of the phone and lift upwards.
    • Be careful not to puncture the battery.
  3. HTC Trophy Power Button Replacement, Display Assembly: passo 3, immagine 1 di 3 HTC Trophy Power Button Replacement, Display Assembly: passo 3, immagine 2 di 3 HTC Trophy Power Button Replacement, Display Assembly: passo 3, immagine 3 di 3
    • Remove the 5 screws holding the two phone halves together.
    • Three 4mm long T5 Torx screws.
    • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
    • One 4mm long Philips #000 screw.
    • Remove the installed SIM card if one is present.
  4. HTC Trophy Power Button Replacement: passo 4, immagine 1 di 3 HTC Trophy Power Button Replacement: passo 4, immagine 2 di 3 HTC Trophy Power Button Replacement: passo 4, immagine 3 di 3
    • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
    • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
    • The volume button will fall out when the phone is opened.
    • The black sticker beneath the battery will rip once the phone is separated.
  5. HTC Trophy Power Button Replacement: passo 5, immagine 1 di 3 HTC Trophy Power Button Replacement: passo 5, immagine 2 di 3 HTC Trophy Power Button Replacement: passo 5, immagine 3 di 3
    • Remove the three screws holding the mother board to the display assembly.
    • One 2mm long Philips #000 screw.
    • Two 4mm long T5 Torx screws in the holes of the plastic.
  6. HTC Trophy Power Button Replacement: passo 6, immagine 1 di 3 HTC Trophy Power Button Replacement: passo 6, immagine 2 di 3 HTC Trophy Power Button Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the black tape cover the ribbon cable connectors with tweezers.
    • Disconnect the ribbon cables from the connectors.
    • Ribbon cables are extremely fragile.
  7. HTC Trophy Power Button Replacement: passo 7, immagine 1 di 2 HTC Trophy Power Button Replacement: passo 7, immagine 2 di 2
    • Remove power button from the top of the phone with tweezers.
  8. HTC Trophy Power Button Replacement: passo 8, immagine 1 di 3 HTC Trophy Power Button Replacement: passo 8, immagine 2 di 3 HTC Trophy Power Button Replacement: passo 8, immagine 3 di 3
    • Use the iFixit opening tool to separate the motherboard from the display assembly.
  9. HTC Trophy Power Button Replacement, Motherboard: passo 9, immagine 1 di 3 HTC Trophy Power Button Replacement, Motherboard: passo 9, immagine 2 di 3 HTC Trophy Power Button Replacement, Motherboard: passo 9, immagine 3 di 3
    • Remove the plastic piece off of the motherboard.
    • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
  10. HTC Trophy Power Button Replacement, Power Button: passo 10, immagine 1 di 2 HTC Trophy Power Button Replacement, Power Button: passo 10, immagine 2 di 2
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 208
