Salta al contenuto principale
HTC Touch Pro 2 Logic Board Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. HTC Touch Pro 2 Logic Board Replacement, Battery: passo 1, immagine 1 di 3 HTC Touch Pro 2 Logic Board Replacement, Battery: passo 1, immagine 2 di 3 HTC Touch Pro 2 Logic Board Replacement, Battery: passo 1, immagine 3 di 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
    Chiedi a FixBot
  2. HTC Touch Pro 2 Logic Board Replacement: passo 2, immagine 1 di 2 HTC Touch Pro 2 Logic Board Replacement: passo 2, immagine 2 di 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
    Chiedi a FixBot
  3. HTC Touch Pro 2 Logic Board Replacement, Housing: passo 3, immagine 1 di 2 HTC Touch Pro 2 Logic Board Replacement, Housing: passo 3, immagine 2 di 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
    Chiedi a FixBot
  4. HTC Touch Pro 2 Logic Board Replacement: passo 4, immagine 1 di 3 HTC Touch Pro 2 Logic Board Replacement: passo 4, immagine 2 di 3 HTC Touch Pro 2 Logic Board Replacement: passo 4, immagine 3 di 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
    Chiedi a FixBot
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 9-64, Walters Spring 2011 Membro di Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 74
Tutti i Tempi: 4,900
