Salta al contenuto principale
HTC One Speaker Replacement
Cosa ti serve
  1. HTC One Speaker Replacement, Speaker: passo 1, immagine 1 di 3 HTC One Speaker Replacement, Speaker: passo 1, immagine 2 di 3 HTC One Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: passo 2, immagine 1 di 1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: passo 3, immagine 1 di 1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: passo 6, immagine 1 di 2 HTC One Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: passo 7, immagine 1 di 2 HTC One Speaker Replacement: passo 7, immagine 2 di 2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: passo 8, immagine 1 di 3 HTC One Speaker Replacement: passo 8, immagine 2 di 3 HTC One Speaker Replacement: passo 8, immagine 3 di 3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: passo 9, immagine 1 di 2 HTC One Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Conclusione
Altre 16 persone hanno completato questa guida.
Alex
Membro da: 09/23/14
664 Reputazione
1 Guida realizzata
USF Tampa, Team 12-1, Blackwell Fall 2014 Membro di USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Membri
7 Guide realizzate
2 Commenti
Ok I will good
Raguraman - Replica
Where to buy speaker???
bharatdshmkh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 19,441
