Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
If you have an issue with your speaker as stated in our troubleshooting page ( HTC One M7 Troubleshooting ) then this guide is for you.
  1. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. Pry the back loose and lift. The back panel will come off with time.
    • Pry the back loose and lift. The back panel will come off with time.
  3. Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. Use tweezers to get underneath the motherboard to lift.
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. Remove the motherboard completely out of the phone. May stay attached from one end by tape.
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. Use the blue opening tool to pry the battery from the frame. Some force will be needed since the battery is glued to the frame.
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. Completely remove the motherboard. Completely remove the motherboard. Completely remove the motherboard.
    • Completely remove the motherboard.
  9. Remove the #000 screws around the speaker that are located at the bottom of the frame. Lift the speaker out of the frame.
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Conclusione
Altre 16 persone hanno completato questa guida.
Alex
Membro da: 23/09/2014
672 Reputazione
1 Guida realizzata
USF Tampa, Team 12-1, Blackwell Fall 2014 Membro di USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Membri
7 Guide realizzate
Ok I will good
Raguraman - Replica
Where to buy speaker???
bharatdshmkh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 18,617
