Salta al contenuto principale
HP ZBook 15 Screen Replacement
Cosa ti serve
  1. HP ZBook 15 Screen Replacement, Battery: passo 1, immagine 1 di 2 HP ZBook 15 Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Screen Replacement, Screen: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
  3. HP ZBook 15 Screen Replacement: passo 3, immagine 1 di 1
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
  4. HP ZBook 15 Screen Replacement: passo 4, immagine 1 di 2 HP ZBook 15 Screen Replacement: passo 4, immagine 2 di 2
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
  5. HP ZBook 15 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
  6. HP ZBook 15 Screen Replacement: passo 6, immagine 1 di 2 HP ZBook 15 Screen Replacement: passo 6, immagine 2 di 2
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
Conclusione
Altre 9 persone hanno completato questa guida.
Grant Terris
Membro da: 01/30/15
2.834 Reputazione
12 Guide realizzate
Cal Poly, Team 8-43, Amido Winter 2015 Membro di Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membri
15 Guide realizzate
3 Commenti
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - Replica
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - Replica
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 58
Tutti i Tempi: 16,545
