Salta al contenuto principale
HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement
Cosa ti serve
  1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: passo 1, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: passo 1, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: passo 1, immagine 3 di 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: passo 2, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: passo 2, immagine 2 di 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 3, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 3, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 3, immagine 3 di 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 4, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 4, immagine 2 di 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: passo 5, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: passo 5, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 6, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 6, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: passo 6, immagine 3 di 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: passo 7, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: passo 7, immagine 2 di 2
    • The joystick controller is soldered directly to the circuit board. You can find instructions for removing soldered components here.
    • The joystick controller is secured by 12 solder connections. Once these have been desoldered, the controller can be removed.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S18-G5, White Winter 2019 Membro di Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Membri
14 Guide realizzate
2Commenti sulla guida
You can solder replacement Xbox One analog sticks right? I have some stick drift and can’t test this until my university reopens, but when it does I want to try fixing it.
Edit: I have the Dell controllers but they seem identical to the HP ones in this guide.
Vincent - Replica
I think this might be the stick: https://www.mouser.com/ProductDetail/Alp...
Alps RKJXV 23 degree 10K ohm multi-directional switches
I haven’t soldered it yet so do not take my word as fact, it just looks right.
Vincent - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,530
