Salta al contenuto principale
HP Stream 8 Speakers Replacement
Cosa ti serve
  1. HP Stream 8 Speakers Replacement, Midframe: passo 1, immagine 1 di 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Speakers Replacement: passo 2, immagine 1 di 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Speakers Replacement: passo 3, immagine 1 di 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Speakers Replacement: passo 4, immagine 1 di 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Speakers Replacement, Speakers: passo 5, immagine 1 di 2 HP Stream 8 Speakers Replacement, Speakers: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Locate the two speakers at the bottom of the device.
    • Remove the two speakers by prying them out using a pair of tweezers.
    • Detach the red and black power wiring from the device and pull the speakers entirely out of the HP Stream 8.
    • Remember where the red and black wiring is connected to the device.
    • The power wires are soldered to the device and will be difficult to detach.
  6. HP Stream 8 Speakers Replacement: passo 6, immagine 1 di 1
    • Grab the two replacement speakers and the soldering iron.
    • Locate where the red and black power wiring previously connected to the device.
    • Attach and re-solder the red and black power wiring.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Conclusione
Nick Miller
Membro da: 04/11/16
669 Reputazione
6 Guide realizzate
Cal Poly, Team 34-14, Maness Spring 2016 Membro di Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 357
