Introduzione
Before beginning, make sure you discharge any static electricity stored in your hands by either touching a metal object (preferably grounded) or using the anti-static wrist strap.
Cosa ti serve
Make sure the tablet is powered off before beginning.
Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
