Introduzione
Speakers can malfunction over time due to several factors such as damage and wear causing blow-out severely compromising the audio quality of the product.
During the replacement of the speaker in the HP Stream 13-c002dx the user will need to exercise caution when handling electronic parts with lithium ion batteries that potentially pose a hazard.⏎
If a battery becomes swollen take precautions.
The laptop will need to be disassembled to gain access to the internal components and remove the speakers to be replaced.
Cosa ti serve
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
You will notice various screws located on the outer edges of the speakers. Using your Philips screwdriver, remove each of these screws.
Connecting the two speakers is a red and black wire located at the edge of the battery. Using your flathead screwdriver, lift the wire upward.
