Salta al contenuto principale
HP Stream 11-y010nr Battery Replacement
Cosa ti serve
  1. HP Stream 11-y010nr Battery Replacement, Keyboard: passo 1, immagine 1 di 3 HP Stream 11-y010nr Battery Replacement, Keyboard: passo 1, immagine 2 di 3 HP Stream 11-y010nr Battery Replacement, Keyboard: passo 1, immagine 3 di 3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Battery Replacement: passo 2, immagine 1 di 2 HP Stream 11-y010nr Battery Replacement: passo 2, immagine 2 di 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Battery Replacement: passo 3, immagine 1 di 2 HP Stream 11-y010nr Battery Replacement: passo 3, immagine 2 di 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Battery Replacement: passo 4, immagine 1 di 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Battery Replacement: passo 5, immagine 1 di 3 HP Stream 11-y010nr Battery Replacement: passo 5, immagine 2 di 3 HP Stream 11-y010nr Battery Replacement: passo 5, immagine 3 di 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Battery Replacement, Battery: passo 6, immagine 1 di 3 HP Stream 11-y010nr Battery Replacement, Battery: passo 6, immagine 2 di 3 HP Stream 11-y010nr Battery Replacement, Battery: passo 6, immagine 3 di 3
    • Use your fingers or a spudger to pull the battery cable out from its connector.
  7. HP Stream 11-y010nr Battery Replacement: passo 7, immagine 1 di 2 HP Stream 11-y010nr Battery Replacement: passo 7, immagine 2 di 2
    • Unscrew the six 0.4mm screws surrounding the battery with a Phillips #1 screwdriver.
  8. HP Stream 11-y010nr Battery Replacement: passo 8, immagine 1 di 3 HP Stream 11-y010nr Battery Replacement: passo 8, immagine 2 di 3 HP Stream 11-y010nr Battery Replacement: passo 8, immagine 3 di 3
    • Carefully lift up on the battery.
    • If the black and white wire on the bottom is intertwined with the bracket, gently pull the wire off the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 65
Tutti i Tempi: 3,065
