Introduzione
This guide will help you remove and replace the motherboard in the HP Pavilion x360 14m-ba114dx. The motherboard is tasked with taking all of the components of the device and connecting them to create a functioning laptop. The symptoms of a failed motherboard are typically a completely dead system. Other than a dead system, there are not usually any other indicators given by the computer, due to the fact that the motherboard is in control of most of the components. For more information on a faulty motherboard, please visit this page.
Removal of the motherboard is necessary to remove the fan and the DC power jack; if you are having problems with either of these components please consult this troubleshooting page.
Finally, a prerequisite to this guide is removal of the battery. If you notice once the laptop is open that the battery is swollen, remove it with caution. If swollen, do not charge the battery, keep the battery at a stable room temperature, and dispose of it properly at a recycling center. This page will help you deal with a swollen battery. Another important thing is to make sure that you unplug your device from any external power sources and completely power it off before beginning this replacement.
Cosa ti serve
Using a #0 Phillips-head screwdriver, remove the three 5 mm screws along the bottom of the back cover.
Using a #0 Phillips-head screwdriver, remove the 6 mm screw at the top of the back cover.
Using the plastic Spudger, remove the ZIF connector connecting the power button board to the motherboard. Remove the connector by popping the cap up on top of the connector and sliding it out of its slot.
Use the Blunt Tweezers to disconnect the Wireless Card Antenna Cables. Start with the cable labeled M2, which is connected to Port #2. To disconnect he cable, grab it on both sides with the tweezers and pull up.
Use the Blunt Tweezers to disconnect the Antenna Cable labeled A1, which is connected to Port #1. To disconnect he cable, grab it on both sides with the tweezers and pull up.
Using the Blunt Tweezers, unwind the cables from the track to the right of the speaker. The cables are held in place by two black hooks.
Using the curved end of the Halberd Spudger, disconnect the Speaker Cable from the port that connects it to the motherboard by prying it out of the port.
Using the same process to disconnect the DC Power Jack Cable from the port that connects it to the motherboard.
Altre 2 persone hanno completato questa guida.
