Salta al contenuto principale
HP Pavilion x360 11-p110nr Battery Replacement
Cosa ti serve
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion x360 11-p110nr Battery Replacement, Battery: passo 1, immagine 2 di 2
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion x360 11-p110nr Battery Replacement: passo 2, immagine 2 di 2
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: passo 3, immagine 1 di 1
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 629
