Introduzione
Laptop cooking your lap? This guide will walk you through replacing your fan.
For help applying thermal paste, you can reference the iFixit Thermal Paste Application guide.
Cosa ti serve
Unscrew one Phillips #1 screw from the back panel.
Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
Use your fingers, plastic opening tools, or pliers to pull the silver brackets away from the RAM.
Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
Unscrew one 7 mm Phillips #1 screw from the bottom left corner of the motherboard.
Altre 45 persone hanno completato questa guida.
16 Commenti
I had to stop at stap 14 because i couldnt open my laptop, lifting the screen took the plastic piece around the keyboard loose. I tried to return my staps ( to still have a computer) but that plastic piece wont fit back. And i,still cant open my screen.
This worked well for accessing and cleaning the fan. Thanks.
I just wanted to say THANK YOU for posting this instructional page. I know this took a lot of time on your part plus you done this for free to boot. It is because of people like you that make the lives of others PC life much MUCH easier!
Thank you so much! It helped me a lot although I had a different g7 model.
Thanks!!! I was able to fix my laptop.
