Salta al contenuto principale
HP Pavilion dv6-6180us Motherboard Replacement
Cosa ti serve
  1. HP Pavilion dv6-6180us Motherboard Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Motherboard Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Motherboard Replacement: passo 4, immagine 1 di 1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Motherboard Replacement: passo 5, immagine 1 di 1
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Motherboard Replacement: passo 6, immagine 1 di 1
    • Unplug the hard drive wire to detach the hard drive.
    Don't forget to unplug 2 connectors next to the drive's connector. They're not mentioned anywhere in the guide but you won't remove the motherboard with them.
    Krzeszny - Replica
  7. HP Pavilion dv6-6180us Motherboard Replacement, Motherboard: passo 7, immagine 1 di 2 HP Pavilion dv6-6180us Motherboard Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove a 3.5 mm screw that is securing DVD player with screwdriver PH1.
  8. HP Pavilion dv6-6180us Motherboard Replacement: passo 8, immagine 1 di 1
    • Slide DVD player to the left and pull to remove completely.
  9. HP Pavilion dv6-6180us Motherboard Replacement: passo 9, immagine 1 di 1
    • Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
    • Unscrew nine 5 mm screws with PH 1 screwdriver.
    • Unscrew four 4 mm screws with PH 1 screwdriver.
  10. HP Pavilion dv6-6180us Motherboard Replacement: passo 10, immagine 1 di 2 HP Pavilion dv6-6180us Motherboard Replacement: passo 10, immagine 2 di 2
    • Flip side up and open laptop.
    • Pry open the keyboard using a plastic opening tool starting from the top.
    • Lift up keyboard gently because a silver ribbon is still attaching it to the laptop.
  11. HP Pavilion dv6-6180us Motherboard Replacement: passo 11, immagine 1 di 3 HP Pavilion dv6-6180us Motherboard Replacement: passo 11, immagine 2 di 3 HP Pavilion dv6-6180us Motherboard Replacement: passo 11, immagine 3 di 3
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard connector cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  12. HP Pavilion dv6-6180us Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  13. HP Pavilion dv6-6180us Motherboard Replacement: passo 13, immagine 1 di 1
    • Place the computer on its side
    • Separate top panel from bottom frame.
  14. HP Pavilion dv6-6180us Motherboard Replacement: passo 14, immagine 1 di 2 HP Pavilion dv6-6180us Motherboard Replacement: passo 14, immagine 2 di 2
    • Pop open rest palm assembly.
  15. HP Pavilion dv6-6180us Motherboard Replacement: passo 15, immagine 1 di 1
    • Pull ribbon to detach from bottom panel.
  16. HP Pavilion dv6-6180us Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove two 5mm screws securing fan, using PH1 screwdriver.
    You forgot about the screw that secures the motherboard on the bottom left. It's in the photo.
    Krzeszny - Replica
  17. HP Pavilion dv6-6180us Motherboard Replacement: passo 17, immagine 1 di 1
    • Flip laptop over.
    • Remove two 4mm screws securing antenna using PH 1 screwdriver.
    • Pull antenna to the right to remove.
  18. HP Pavilion dv6-6180us Motherboard Replacement: passo 18, immagine 1 di 1
    • Flip laptop side up.
    • Pull off yellow insulating tape.
  19. HP Pavilion dv6-6180us Motherboard Replacement: passo 19, immagine 1 di 2 HP Pavilion dv6-6180us Motherboard Replacement: passo 19, immagine 2 di 2
    • Grab tab on left top corner and remove black wire.
    • Remove white input attachment.
  20. HP Pavilion dv6-6180us Motherboard Replacement: passo 20, immagine 1 di 1
    • Hold the motherboard and pull to the right.
    • The plugs on the left may be difficult to snap out.
  21. HP Pavilion dv6-6180us Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove entire motherboard.
Conclusione
Altre 10 persone hanno completato questa guida.
CSU Fullerton, Team 1-2, Bruce Fall 2016 Membro di CSU Fullerton, Team 1-2, Bruce Fall 2016
CSUF-BRUCE-F16S1G2
4 Membri
4 Guide realizzate
5 Commenti
Great tutorial. Thanks!!!!
victor4pro - Replica
Nothing, thank you very much, it is a pleasure to help more people
Tomas - Replica
very Excellent tutorial …… Thank you
Hussein Knani - Replica
Excellent tutorial …. thank you
Tomas -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 34
Tutti i Tempi: 5,508
