Salta al contenuto principale
HP Pavilion dv4000 Heat Sink Replacement
Cosa ti serve
  1. HP Pavilion dv4000 Heat Sink Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Heat Sink Replacement: passo 2, immagine 1 di 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Heat Sink Replacement: passo 3, immagine 1 di 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Heat Sink Replacement, Heat Sink: passo 4, immagine 1 di 1
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  5. HP Pavilion dv4000 Heat Sink Replacement: passo 5, immagine 1 di 1
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  6. HP Pavilion dv4000 Heat Sink Replacement: passo 6, immagine 1 di 2 HP Pavilion dv4000 Heat Sink Replacement: passo 6, immagine 2 di 2
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  7. HP Pavilion dv4000 Heat Sink Replacement: passo 7, immagine 1 di 2 HP Pavilion dv4000 Heat Sink Replacement: passo 7, immagine 2 di 2
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  8. HP Pavilion dv4000 Heat Sink Replacement: passo 8, immagine 1 di 2 HP Pavilion dv4000 Heat Sink Replacement: passo 8, immagine 2 di 2
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  9. HP Pavilion dv4000 Heat Sink Replacement: passo 9, immagine 1 di 1
    • To reapply thermal paste, check out iFixit's guide here.
Conclusione
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 580
