Introduzione
The charger port is the portion of the laptop that connects the power source to the battery of the laptop to charge it. Typically, this part of the laptop is used frequently and can wear to through is extensive usage. If this port does not work, the battery will not charge, and therefore the device will not turn on or hold power. This guide will show how to remove and replace a charger port with a new functional charger port. For more information on the effects a faulty battery port can cause please check out our troubleshooting page. Please make sure the device is turned off and unplugged prior to starting.
Cosa ti serve
Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
The charging port is attached to the motherboard and is on the right side of the device if it is facing you.
Remove the charging port from motherboard by hand.
