Salta al contenuto principale
HP Pavilion 15-n210dx Keyboard Replacement
Cosa ti serve
  1. HP Pavilion 15-n210dx Keyboard  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over.
  2. HP Pavilion 15-n210dx Keyboard  Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-n210dx Keyboard  Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-n210dx Keyboard  Replacement: passo 2, immagine 3 di 3
    • Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
  3. HP Pavilion 15-n210dx Keyboard  Replacement, Keyboard: passo 3, immagine 1 di 1
    • Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
  4. HP Pavilion 15-n210dx Keyboard  Replacement: passo 4, immagine 1 di 1
    • Open the laptop and use a spudger gently to get under the keyboard. Loosen the keyboard on all sides and then lift it up.
  5. HP Pavilion 15-n210dx Keyboard  Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-n210dx Keyboard  Replacement: passo 5, immagine 2 di 2
    • Use the spudger to unhinge the fastener and remove the connector.
    • The keyboard should be completely detached from the computer now.
Conclusione
Brayan Rivas
Membro da: 10/25/21
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 273
