Salta al contenuto principale
HP Pavilion 15-cs3xxx Battery Replacement
Cosa ti serve
  1. HP Pavilion 15-cs3xxx Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-cs3xxx Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Power off and unplug the laptop from any power source.
    • Flip the laptop over so the bottom is facing up.
    • Prior to removing the two screws near the hinge, remove the two rubber feet with a spudger or opening tool.
    • Two of the five screws are under the rubber feet nearest the hinges.
    • Use a Phillips screwdriver to remove the five screws on the underside of the laptop.
  2. HP Pavilion 15-cs3xxx Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-cs3xxx Battery Replacement: passo 2, immagine 2 di 2
    • Use an opening tool and picks to carefully pry off the back cover.
    • Work your way around the perimeter and release the clips holding the case to the device.
    • Remove the back case.
  3. HP Pavilion 15-cs3xxx Battery Replacement: passo 3, immagine 1 di 1
    • Use a screwdriver to remove the four screws holding the battery in place.
  4. HP Pavilion 15-cs3xxx Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop.
Conclusione
Following these steps in reverse order to reassemble your device
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 163
Tutti i Tempi: 1,587
