Salta al contenuto principale
HP Pavilion 15-cd040wm Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, immagine 1 di 2 HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, immagine 2 di 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-cd040wm Hard Drive Replacement: passo 2, immagine 2 di 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Hard Drive Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-cd040wm Hard Drive Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-cd040wm Hard Drive Replacement: passo 3, immagine 3 di 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: passo 4, immagine 1 di 2 HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: passo 4, immagine 2 di 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-cd040wm Hard Drive Replacement: passo 5, immagine 2 di 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 2 HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Using a spudger or the opening tool, lift the end closest to the battery until you can hold the hard drive with your hands.
  7. HP Pavilion 15-cd040wm Hard Drive Replacement: passo 7, immagine 1 di 2 HP Pavilion 15-cd040wm Hard Drive Replacement: passo 7, immagine 2 di 2
    • Carefully remove the connector ribbon cable from the elevated end of the hard drive, then remove the hard drive.
Conclusione
Altre 2 persone hanno completato questa guida.
Brian Cornet
Membro da: 10/21/19
316 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,873
