Salta al contenuto principale
HP Pavilion 15-bk020wm Touchscreen Replacement
Cosa ti serve
  1. HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: passo 1, immagine 1 di 2 HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: passo 1, immagine 2 di 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-bk020wm Touchscreen Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-bk020wm Touchscreen Replacement: passo 2, immagine 3 di 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 3, immagine 1 di 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: passo 4, immagine 1 di 2 HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: passo 4, immagine 2 di 2
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 5, immagine 1 di 1
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 6, immagine 1 di 1
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
  7. HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: passo 7, immagine 1 di 2 HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: passo 7, immagine 2 di 2
    • Detach the two cables from the motherboard.
  8. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 8, immagine 1 di 1
    • Unscrew all ten screws (M2.5x4.4) using the Phillips 00 screwdriver from the motherboard. Be sure to unscrew the fan as well.
    • Lift the motherboard with the fan.
  9. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 9, immagine 1 di 2 HP Pavilion 15-bk020wm Touchscreen Replacement: passo 9, immagine 2 di 2
    • Unscrew the screen from the laptop body using Phillips 00. Screw size: M2.5x4.4
  10. HP Pavilion 15-bk020wm Touchscreen Replacement: passo 10, immagine 1 di 1
    • Lift the touchscreen hinges using the plastic opening tool to detach the screen.
    • Obtain the new touchscreen to connect to your device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 5,082
