Salta al contenuto principale
HP Pavilion 15-ba003ds Screen Replacement
Cosa ti serve
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: passo 1, immagine 1 di 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: passo 1, immagine 2 di 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 2, immagine 3 di 3
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 3, immagine 3 di 3
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: passo 4, immagine 1 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 4, immagine 2 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 4, immagine 3 di 3
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: passo 5, immagine 1 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 5, immagine 2 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 5, immagine 3 di 3
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: passo 6, immagine 1 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 6, immagine 2 di 3 HP Pavilion 15-ba003ds Screen Replacement: passo 6, immagine 3 di 3
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: passo 7, immagine 1 di 1
    • Lift the screen away from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 270
