Salta al contenuto principale
HP Pavilion 15-ba003ds RAM Replacement
Cosa ti serve
  1. HP Pavilion 15-ba003ds RAM Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-ba003ds RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: passo 2, immagine 1 di 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-ba003ds RAM Replacement: passo 3, immagine 2 di 2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds RAM Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-ba003ds RAM Replacement: passo 4, immagine 2 di 2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, immagine 1 di 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, immagine 2 di 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, immagine 3 di 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: passo 6, immagine 1 di 2 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: passo 6, immagine 2 di 2
    • To release the RAM, hold and pull the strips outwards on either side of the RAM.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 291
