Salta al contenuto principale
HP Pavilion 15-ba003ds Cooling Fan Replacement
Cosa ti serve
  1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Cooling Fan Replacement, Disc Drive: passo 2, immagine 1 di 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: passo 5, immagine 1 di 3 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: passo 5, immagine 2 di 3 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: passo 5, immagine 3 di 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: passo 6, immagine 1 di 2 HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: passo 6, immagine 2 di 2
    • Remove three black 6mm Phillips #00 screws.
  7. HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 7, immagine 1 di 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 7, immagine 2 di 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 7, immagine 3 di 3
    • Unplug the white connector using your fingers or a spudger.
  8. HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 8, immagine 1 di 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 8, immagine 2 di 3 HP Pavilion 15-ba003ds Cooling Fan Replacement: passo 8, immagine 3 di 3
    • Pull out the fan by hand.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 262
