Salta al contenuto principale
HP Pavilion 13-s128nr Battery Replacement
Cosa ti serve
  1. HP Pavilion 13-s128nr Battery Replacement, Back Panel: passo 1, immagine 1 di 2 HP Pavilion 13-s128nr Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Battery Replacement: passo 2, immagine 1 di 1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion 13-s128nr Battery Replacement: passo 3, immagine 2 di 2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
  4. HP Pavilion 13-s128nr Battery Replacement, Battery: passo 4, immagine 1 di 2 HP Pavilion 13-s128nr Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Lift upwards on the black tabs the purple strip is connected to.
    • Gently pull the purple strip out of its place.
  5. HP Pavilion 13-s128nr Battery Replacement: passo 5, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the five screws holding the battery in place.
  6. HP Pavilion 13-s128nr Battery Replacement: passo 6, immagine 1 di 1
    • Pull the white cable connected to the motherboard out using the iFixit opening tool.
  7. HP Pavilion 13-s128nr Battery Replacement: passo 7, immagine 1 di 1
    • Remove the battery.
    • There are little snap tabs on the right side of the battery. Be sure not to break them by pulling the battery out towards the left side.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,186
