Salta al contenuto principale
HP Pavilion 13-P110NR Screen Replacement
Cosa ti serve
  1. HP Pavilion 13-P110NR Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove the back of the laptop screen using a black nylon spudger.
  2. HP Pavilion 13-P110NR Screen Replacement: passo 2, immagine 1 di 1
    • Detach the wires from the green circuit boards located at the bottom.
    • Remove three 3.0 mm #00 Philips screws from the circuit board on the left.
    • Remove two 4.0 mm #00 Philips screws from the small circuit board on the right.
  3. HP Pavilion 13-P110NR Screen Replacement: passo 3, immagine 1 di 1
    • Detach the wires located just above the bigger green circuit board.
  4. HP Pavilion 13-P110NR Screen Replacement: passo 4, immagine 1 di 2 HP Pavilion 13-P110NR Screen Replacement: passo 4, immagine 2 di 2
    • Remove six 4.0 mm Philips #00 screws from the outside of the frame.
    • Remove five 3.0 mm Philips #00 screws from the outside of the frame.
    • Remove the one 3.0 mm Philips #00 screw hidden under the circuit board.
  5. HP Pavilion 13-P110NR Screen Replacement: passo 5, immagine 1 di 1
    • Remove the band that is attached to the circuit board, located on the right side.
  6. HP Pavilion 13-P110NR Screen Replacement: passo 6, immagine 1 di 1
    • Lift the frame and attached hardware from two corners of the frame.
    • Remove the frame from the device.
  7. HP Pavilion 13-P110NR Screen Replacement: passo 7, immagine 1 di 2 HP Pavilion 13-P110NR Screen Replacement: passo 7, immagine 2 di 2
    • Remove the tape located at the top of the frame.
    • Remove the bands from underneath the tape.
  8. HP Pavilion 13-P110NR Screen Replacement: passo 8, immagine 1 di 2 HP Pavilion 13-P110NR Screen Replacement: passo 8, immagine 2 di 2
    • Use the spudger to lift the case, which is attached at four spots by pegs.
    • Remove the metal cover and layers of film.
  9. HP Pavilion 13-P110NR Screen Replacement: passo 9, immagine 1 di 1
    • Use the spudger to gently lift up the screen.
    • There are two layers, go under the bottom layer.
  10. HP Pavilion 13-P110NR Screen Replacement: passo 10, immagine 1 di 1
    • After you get some space at the top of the screen, proceed by using a thin board to gently remove the screen from the frame.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 425
