Salta al contenuto principale
HP Pavilion 13-P110NR Keyboard Replacement
Cosa ti serve
  1. HP Pavilion 13-P110NR Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the two rubber feet closest to the black hinge.
  2. HP Pavilion 13-P110NR Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion 13-P110NR Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. HP Pavilion 13-P110NR Keyboard Replacement: passo 3, immagine 1 di 1
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. HP Pavilion 13-P110NR Keyboard Replacement: passo 4, immagine 1 di 1
    • Lift the metal brace and remove it from the device.
  5. HP Pavilion 13-P110NR Keyboard Replacement: passo 5, immagine 1 di 2 HP Pavilion 13-P110NR Keyboard Replacement: passo 5, immagine 2 di 2
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  6. HP Pavilion 13-P110NR Keyboard Replacement: passo 6, immagine 1 di 2 HP Pavilion 13-P110NR Keyboard Replacement: passo 6, immagine 2 di 2
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  7. HP Pavilion 13-P110NR Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  8. HP Pavilion 13-P110NR Keyboard Replacement: passo 8, immagine 1 di 3 HP Pavilion 13-P110NR Keyboard Replacement: passo 8, immagine 2 di 3 HP Pavilion 13-P110NR Keyboard Replacement: passo 8, immagine 3 di 3
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  9. HP Pavilion 13-P110NR Keyboard Replacement: passo 9, immagine 1 di 1
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  10. HP Pavilion 13-P110NR Keyboard Replacement: passo 10, immagine 1 di 1
    • Remove the metal plate to reveal the keyboard.
  11. HP Pavilion 13-P110NR Keyboard Replacement: passo 11, immagine 1 di 2 HP Pavilion 13-P110NR Keyboard Replacement: passo 11, immagine 2 di 2
    • Remove the keyboard from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 345
