Salta al contenuto principale
HP Pavilion 13-P110NR Battery Replacement
Cosa ti serve
  1. HP Pavilion 13-P110NR Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Gently use the black nylon spudger to pry the back casing from the screen until it snaps apart.
  2. HP Pavilion 13-P110NR Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 13-P110NR Battery Replacement: passo 2, immagine 2 di 2
    • Flip the gray latch back and remove the blue and white band of wires from the green motherboard.
  3. HP Pavilion 13-P110NR Battery Replacement: passo 3, immagine 1 di 3 HP Pavilion 13-P110NR Battery Replacement: passo 3, immagine 2 di 3 HP Pavilion 13-P110NR Battery Replacement: passo 3, immagine 3 di 3
    • Pull the black and white wire out of the green circuit board.
    • Pull the red and black wire out on the other side of the device.
  4. HP Pavilion 13-P110NR Battery Replacement: passo 4, immagine 1 di 2 HP Pavilion 13-P110NR Battery Replacement: passo 4, immagine 2 di 2
    • Unscrew the three screws from the circuit board using a Phillips #00 screwdriver.
    • Unscrew two 4.0 mm Philips #00 screws from the left side of the battery.
    • Unscrew two 3.0 mm Philips #00 screws from the right side of the battery.
  5. HP Pavilion 13-P110NR Battery Replacement: passo 5, immagine 1 di 2 HP Pavilion 13-P110NR Battery Replacement: passo 5, immagine 2 di 2
    • Unplug the bound (red, white and black) wires connecting the battery and the motherboard.
  6. HP Pavilion 13-P110NR Battery Replacement: passo 6, immagine 1 di 2 HP Pavilion 13-P110NR Battery Replacement: passo 6, immagine 2 di 2
    • Carefully remove the battery without pulling the copper information transmitter out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 569
