Salta al contenuto principale
HP Pavilion 11 x360 Fan Replacement
Cosa ti serve
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: passo 1, immagine 1 di 2 HP Pavilion 11 x360 Fan Replacement, Remove Screws: passo 1, immagine 2 di 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: passo 2, immagine 1 di 3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: passo 2, immagine 2 di 3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: passo 2, immagine 3 di 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: passo 3, immagine 1 di 2 HP Pavilion 11 x360 Fan Replacement, Detach Cable: passo 3, immagine 2 di 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: passo 4, immagine 1 di 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: passo 5, immagine 1 di 2 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: passo 5, immagine 2 di 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
Conclusione
Altre 6 persone hanno completato questa guida.
Natalie
Membro da: 01/22/15
937 Reputazione
4 Guide realizzate
Cal Poly, Team 19-9, Maness Winter 2015 Membro di Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,885
