Salta al contenuto principale
HP Media Center 876x Optical Drive Replacement
Cosa ti serve
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: passo 1, immagine 1 di 2 HP Media Center 876x Optical Drive Replacement, Side Panel: passo 1, immagine 2 di 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: passo 2, immagine 1 di 3 HP Media Center 876x Optical Drive Replacement: passo 2, immagine 2 di 3 HP Media Center 876x Optical Drive Replacement: passo 2, immagine 3 di 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: passo 3, immagine 1 di 2 HP Media Center 876x Optical Drive Replacement, Front Cover: passo 3, immagine 2 di 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: passo 4, immagine 1 di 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: passo 5, immagine 1 di 2 HP Media Center 876x Optical Drive Replacement: passo 5, immagine 2 di 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: passo 6, immagine 1 di 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: passo 6, immagine 2 di 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: passo 6, immagine 3 di 3
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: passo 7, immagine 1 di 3 HP Media Center 876x Optical Drive Replacement: passo 7, immagine 2 di 3 HP Media Center 876x Optical Drive Replacement: passo 7, immagine 3 di 3
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: passo 8, immagine 1 di 3 HP Media Center 876x Optical Drive Replacement: passo 8, immagine 2 di 3 HP Media Center 876x Optical Drive Replacement: passo 8, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: passo 9, immagine 1 di 2 HP Media Center 876x Optical Drive Replacement: passo 9, immagine 2 di 2
    • Remove the optical drive completely from its port.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 6-1, Benson Spring 2014 Membro di Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 523
