Salta al contenuto principale
HP Envy x360 m6-w103dx Speakers Replacement
Cosa ti serve
  1. HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: passo 1, immagine 1 di 2 HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: passo 1, immagine 2 di 2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Speakers Replacement: passo 2, immagine 1 di 2 HP Envy x360 m6-w103dx Speakers Replacement: passo 2, immagine 2 di 2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Speakers Replacement: passo 3, immagine 1 di 3 HP Envy x360 m6-w103dx Speakers Replacement: passo 3, immagine 2 di 3 HP Envy x360 m6-w103dx Speakers Replacement: passo 3, immagine 3 di 3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Speakers Replacement: passo 4, immagine 1 di 3 HP Envy x360 m6-w103dx Speakers Replacement: passo 4, immagine 2 di 3 HP Envy x360 m6-w103dx Speakers Replacement: passo 4, immagine 3 di 3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Speakers Replacement, Speakers: passo 5, immagine 1 di 1
    • Disconnect the connector on the left speaker by gently pulling on each side of the connector.
    • Do not pull directly on the wires.
  6. HP Envy x360 m6-w103dx Speakers Replacement: passo 6, immagine 1 di 2 HP Envy x360 m6-w103dx Speakers Replacement: passo 6, immagine 2 di 2
    • Unscrew the three 6mm screws using a #00 Phillips screwdriver, one on the right speaker and two on the left speaker.
  7. HP Envy x360 m6-w103dx Speakers Replacement: passo 7, immagine 1 di 3 HP Envy x360 m6-w103dx Speakers Replacement: passo 7, immagine 2 di 3 HP Envy x360 m6-w103dx Speakers Replacement: passo 7, immagine 3 di 3
    • Remove each speaker one at a time.
    • Carefully remove the wire connecting the two speakers, which is tucked under small plastic hooks on the bottom edge of the device.
Conclusione
Steven Ngo
Membro da: 10/10/19
927 Reputazione
7 Guide realizzate
Cal Poly, Team S12-G2, Regan Fall 2019 Membro di Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
4 Membri
23 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 650
