Introduzione
This replacement guide is for the display of the HP Envy x360 m6-w103dx. The display is so you can see what is happening on the screen. All you need to complete this guide is a plastic opening tool and a #0 Phillips screwdriver.
Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the display doesn’t require any special technical skills. This is not dangerous, but caution is recommended to keep from breaking the screen.
Cosa ti serve
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
