Introduzione
Use this guide to replace your HP Elitebook Folio 9470m Trackpad
If your laptop no longer is responsive to movements on the trackpad or does not function properly, your trackpad is likely faulty and may need replacement. There are no special skills involved in the replacement if the trackpad.
Before using this guide, make sure to review the troubleshooting page to ensure that the trackpad doesn't have any driver issues or other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Cosa ti serve
Un commento
Please make sure the Track Pad is not "turned off:" (HP Folio has a Track Pad on/off feature by double-tap in upper left hand corner)
1) Double tap the upper left corner of the Track Pad by the Amber LED
2a) If the LED is "On" then the Track Pad is "Off"
2b) If the LED is "Off" then the Track Pad is "On"
