Salta al contenuto principale
HP EliteBook x360 830 G7 Solid State Drive Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: passo 1, immagine 1 di 2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: passo 1, immagine 2 di 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: passo 2, immagine 1 di 1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, immagine 1 di 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, immagine 2 di 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: passo 4, immagine 1 di 1
    • Gently pull the SSD free from the M.2 socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 81
Tutti i Tempi: 1,555
