Salta al contenuto principale
HP EliteBook 8560w Keyboard Replacement
Cosa ti serve
  1. HP EliteBook 8560w Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8560w Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Keyboard Replacement: passo 2, immagine 1 di 1
    • Pull the battery out.
  3. HP EliteBook 8560w Keyboard Replacement, Back Panel: passo 3, immagine 1 di 2 HP EliteBook 8560w Keyboard Replacement, Back Panel: passo 3, immagine 2 di 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Keyboard Replacement: passo 4, immagine 1 di 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: passo 5, immagine 1 di 2 HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: passo 5, immagine 2 di 2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Keyboard Replacement: passo 6, immagine 1 di 3 HP EliteBook 8560w Keyboard Replacement: passo 6, immagine 2 di 3 HP EliteBook 8560w Keyboard Replacement: passo 6, immagine 3 di 3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Keyboard Replacement: passo 7, immagine 1 di 2 HP EliteBook 8560w Keyboard Replacement: passo 7, immagine 2 di 2
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Keyboard Replacement, Keyboard: passo 8, immagine 1 di 1
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Keyboard Replacement: passo 9, immagine 1 di 3 HP EliteBook 8560w Keyboard Replacement: passo 9, immagine 2 di 3 HP EliteBook 8560w Keyboard Replacement: passo 9, immagine 3 di 3
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Keyboard Replacement: passo 10, immagine 1 di 3 HP EliteBook 8560w Keyboard Replacement: passo 10, immagine 2 di 3 HP EliteBook 8560w Keyboard Replacement: passo 10, immagine 3 di 3
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,604
